Toyota Techstream V13.00.022 [02.2018] + ACTIVATION
Toyota
[Image: 2018-02-03_10-46-47.png]
[Image: 2018-02-05_10-08-59.png]
[Image: 2018-02-05_10-10-29.png]
Versaion:   V13.00.022
Date of update: 02.2018
TIS techstream is the replacement for the Diagnostic Tester. It combines the functionality of TIS and the scantool into a single portable device. With TIS techstream, technicians can simultaneously view/analyze on-board vehicle data, browse relevant TIS service documents, and reprogram vehicles all from the driver's seat via wireless connection to TIS.
