Toyota Techstream v14.10.028 [04.2019] + ACTIVATION
Toyota
Versaion:   V14.10.02818
Date of update: 04.2019
TIS techstream is the replacement for the Diagnostic Tester. It combines the functionality of TIS and the scantool into a single portable device. With TIS techstream, technicians can simultaneously view/analyze on-board vehicle data, browse relevant TIS service documents, and reprogram vehicles all from the driver's seat via wireless connection to TIS.
