Terex DUMP TRUCKS Parts Book + Glass Reference
Terex
2008
Models Included:
TA25 G7 Articulated Truck Cummins QSC8 Tier3 280hp with ZF 6WG210 Trans. (non-retarder) Serial No. A8741011 through A8741037
TA25 G7 Articulated Truck (Cummins QSM11 T3 Engine with ZF 6WG-260 Trans & NAF Axles) Serial Nos. A9201011 and above
TA25 Articulated Truck Cummins QSC8 280hp with ZF 6WG210 Trans. (non-retarder) Serial No. A8471011 through A8471113
TA25 / TA27 Articulated Truck (Cummins 6CTA 8.3-C260 Powered with ZF 6WG210 Transmission) Serial No. A8051001 through A8051503
TA27 Articulated Truck (Cummins 6QSL-330 Engine with ZF 6WG-260-II Retarder Trans.) From Serial No. A8251011 to A8251052
TA27 Articulated Truck Cummins QSL-330hp with ZF 6WG-260-II Trans.(non-retarder) Serial No. A8501011 through A8501223
TA27 Articulated Truck Cummins QSM11 Tier3 -335 Powered-(Engine Jake Brake) and ZF 6WG-260 Transmission Serial No. A8681011 through A8681177
TA27 G7 Articulated Truck (Cum QSM11 T3-335 HP Engine, ZF 6WG-260 Trans & NAF Axles) Serial Nos. A8891011 and above
TA27 G7 (IFS) Articulated Truck (Cum QSM11 T3-335 HP Engine, ZF 6WG-260 Trans & NAF Axles) Serial Nos. A8921011 and above
TA27 G7 Articulated Truck Cummins QSM11 Tier3 - 335 Powered - (Engine Jake Brake) and ZF 6WG-260 Transmission Serial No. A8991011 through A8991039
TA30 Articulated Truck (Cummins MTA11-C300 Powered with ZF 6WG260 Transmission) Serial No. A7751001 to A7751432
TA30 Articulated Truck (Cummins MTA11-C300 Powered with ZF 6WG-260-II Transmission) Serial No. A7991001 through A7991662
TA30 Articulated Truck (Cummins QSM11-350 Powered with ZF 6WG-310 Transmission) Serial No. A8281011 through A8281698
TA30 Articulated Truck (Cummins QSM11 Tier3 -350 Powered with ZF 6WG-310 Trans) Serial No. A8591011 through A8591468
TA30RS Articulated Truck Cummins QSM11 Tier3 -335 Powered-Engine Jake Brake and ZF 6WG-260 Transmission-(Retarder Trans. Optional) Serial No. A8781019 through A8781029
TA30 G7 Articulated Truck (Cum QSM11 T3-350 HP Engine, ZF 6WG-310 Trans & NAF Axles) Serial Nos. A8941011 and above
TA30 G7 (IFS) Articulated Truck (Cum QSM11 T3-350 HP Engine, ZF 6WG-310 Trans & NAF Axles) Serial Nos. A8971011 and above
TA30 G7 Articulated Truck (Cummins QSM11 Tier3 - 350 Powered with ZF 6WG-310 Trans) Serial No. A9021011 through A9021129
TA30RS Articulated Truck Cummins QSM11 Tier3 - 335 Powered - (Engine Jake Brake) and ZF 6WG-260 Transmission Serial No. A9051011 through A9051021
TA30RS Articulated Truck Cummins (Cum QSM11 T3-335 HP Engine, ZF 6WG-260 Trans & NAF Axles) Serial Nos. A9081011 and above
TA30 Artic Truck - (Timoney Suspension) (Cummins QSM11-350 Powered with ZF 6WG-310 Transmission) Unit Serial Nos. A8281548 and A8281549
TA35 Articulated Truck (Detroit Diesel Series 60 Powered) Serial No. A7761001 to A7761243 (Serial nos. A7761201 to A7761204 fitted with AP17 ZF Axles)
TA35 Articulated Truck (Detroit Diesel Series 60 Powered) Serial No. A7761244 through A7761362
TA35 Articulated Truck (Detroit Diesel Series 60 (400 hp) Powered) Serial No. A8361001 through A8361185
TA35 G7 Articulated Truck (Detroit Diesel Series 60 Engine with Allison 4500 ORS_R Trans) Serial No. A8621011 through A8621055 April 2006 (also TA35 (EEC only) Serial No. A9421011 )
TA35 G7 (OCDB) Articulated Truck (Detroit Diesel Series 60 Engine with Allison 4500 ORS_R Trans) Serial Nos. A9171011 and above
TA35 G7 (OCDB) Articulated Truck (Europe only) (Detroit Diesel 450HP Series 60 Engine with Allison 4500 ORS_R Trans) Serial Nos. A9461011 and above
TA40 Articulated Truck (Detroit Diesel Series 60 Powered) Serial No. A7771001 through A7771470
TA40 Articulated Truck (Detroit Diesel Series 60 Powered) Serial No. A7771081 to A7771089 (units with ZF AP-17 axles)
TA40 OCDB Articulated Truck (Detroit Diesel Series 60 Powered) Serial No. A8201001 through A8201288
TA40 (OCDB) Articulated Truck (Detroit Diesel Series 60 Engine, ZF 6WG-310 Trans and ZF AP-17 Axles) Serial No. A8421013 through A8421096
TA40 G7 Articulated Truck (Detroit Diesel Series 60 Engine with Allison 4500 ORS_R Trans) Serial Nos. A8651010 and above
TA40 Articulated Truck-(Dry Brakes) (Detroit Diesel Series 60 Powered with ZF 6WG-310 Trans.) From Serial No. A8711011 and above
TA40 (OCDB) Articulated Truck (Detroit Diesel Series 60 Engine, ZF 6WG-310 Transmission and ZF AP17 Axles) Serial No. A8421011 and A8421012
