ACTIA Multi-Di@g v33.06 [I-2015]
ACTIA Multi-Di@g
Diagnostic tool
Languages: English, German (MultiLang)
Type: Diagnostic tool
Date of update: I/2015
License: High
Ideal for the independent garage wanting a truly multi-make diagnostic tool giving in-depth diagnostics on a wide range of European-manufactured cars.
The Access kit is Windows-based, and can connect to any Windows PC or laptop with a USB port (subject to minimum specification).
Direct access to all diagnostics features
With Multi-Diag, you don’t have to be an electronics expert. All features are just a few mouse clicks away via the intuitive, user-friendly interface.
Multi-Diag guides the operator step by step through the job ahead :servicing, wheels and suspension, brakes, air conditioning, anti-pollution, car body, and engine. The workshop mode lets you perform bull’s-eye diagnostics every time.
An expert mode providing advanced ECU diagnostics, physical measurements and configuration capabilities is also available.
MD_ReportAutomatic vehicle detection
As soon as you connect the OBD plug, Multi-Diag automatically identifies the vehicle* (no more manual data entry). Then, a mouse click takes you straight to the diagnostics page matching the make and model of the vehicle.
* Available on vehicles fitted with an EOBD socket.
BTN_express_diagThe Express Diag feature and Diagnostics Report
The Express Diag feature lets you run a comprehensive test across all ECUs in the vehicle in just 1 click. This feature lets you check the vehicle’s electronic status in a few minutes and then prints out a Diagnostics Report. This Diagnostics Report is automatically customisable with your workshop name and details, lists the ECUs tested and gives a detailed rundown of ALL errors identified.
