Cummins Calterm III v3.6.0.014 +MetaFiles [07.2012]
![[Image: 01.png]](https://i.postimg.cc/g2vTPfXc/01.png)
![[Image: 02.png]](https://i.postimg.cc/rpjZDxNv/02.png)
![[Image: 03.png]](https://i.postimg.cc/pT10Zv7C/03.png)
![[Image: 04.png]](https://i.postimg.cc/Jnh6Z0Tt/04.png)
![[Image: 05.png]](https://i.postimg.cc/YSMy2bY6/05.png)
Cummins Calterm 3.6 is an engineering development tool used to monitor Electronic Control Modules for Cummins engine systems and to alter the calibration data contained therein.
Calterm 3.6 is designed to modify fueling calibration parameters and feature settings in an engineering development and test environment.
As is the case with most support tools, Calterm 3.6 attempts to work with all of the features in the ECM. However, this superset of functionality is not always feasible given the rapid growth and change being experienced in Cummins.
The Calterm III application is designed to support a wide variety of users and access levels. The Calterm III tool will eventually replace Calterm II, NGET, Engineering ESDN, Unlock and Field Calterm. As a result, not all users need, or are permitted to use, the full functionality of the tool. With this in mind, Calterm III comes with five user access levels.
Year: 2012
Date of update: 07/2012Cummins Calterm 3.6 is an engineering development tool used to monitor Electronic Control Modules for Cummins engine systems and to alter the calibration data contained therein.
The development process for electronic engines requires PC support tools which interface to the electronic subsystem, and its various feature sets. Calterm 3.6 is used to increase the productivity of the engineers developing electronic engine features by providing diagnostics, simulation, and value manipulation capabilities for Electronic Control Modules (ECMs).
· Level 0 (Service) Enables user with basic Field Calterm functionality
· Level 1 (Standard) Enables user with Calterm II and NGET functionality
· Level 2 (Secure) Enables user with Calterm II, NGET and Unlock tool functionality
· Level 3 (Enterprise) Enables user with Calterm II, NGET, Unlock and Engineering ESDN functionality
· Level 4 (Service Pro) Contains the same functionality as Level 0 (Service) plus the capability to Download to a secure module
