CarProg v9.31 + v8.21 + KEYGEN
[Image: 06.jpg]
[Image: 07.jpg]
[Image: KEYGEN.png]
1. With latest software version: V8.21 and V9.31. Software V8.21 can be used online but need to active. Software V9.31 can be used without activation
2. Support WIN XP, WIN7, WIN8, WIN10 Operation system.
3. Can perform airbag reset function well
4 new audi dash support, support newer airbags
5. Including much more authorization
V8.21 CARPROG Functions:
1. Make the Universal tool - CARPROG inside have powerful 16-bit MPU and full set of automotive interface drivers. In basic version you will get hardware with extra functions: 12 input/output pins for EEPROM in-circuit programmer, future possibility\'s to make on the same hardware Microcontroller programmer, K-line diagnostic, CAN line diagnostic,+5V/+12V output, USB, power supply only from USB.
2. Make the Low Cost tool - with CARPROG basic you will receive many extra functions (like car radio code calculator CC1, EEPROM programmer and VAG dashboard\'s programmer by CAN) and all additional software\'s you can buy extra according your need.
3. Make it User Friendly - Win XP software, works without any installations, on all PC, use USB to PC link, all adapters schematics diagrams on-line.
4. The best function of it is airbag reset, and it cannot do by antenna.
CARPROG FULL V8.21 Software:
ECU-OP-EL - OP-EL login reader from motor hybrid ECU. Works with Bo-sch ME1.5.5, Siem-ens SIMTEC71, SIMTEC71.1, Delco Diesel, Delco Multec.
OP-EL CAN - Op-el ECU by CAN programmer - read/change mileage in EDC16, MT35E, HSFI 2.2 read PIN, reset ECU
PSG16 - Op-el PSG16 diesel pump by OBDII - read/change mileage, read PIN, reset ECU
OPEC28 - O-pel Sie-mens Simtec ECU Tool Advanced
Carprog Full Airbag: S5.1 - VAG (Au-di, VW, Sko-da, Se-at) Airbag Reset Tool S5.2 - B-M-W Airbag Reset Tool S5.3 - Mer-ce-des Be-nz Airbag Reset Tool S5.4 - FO-RD Airbag Reset Tool S5.5 - G-M Airbag Reset Tool by OBDII S5.6 - CARPROG CR16 Airbag tool - Au-di, Merce-des, Fo-rd, Vo-lvo S5.7 - Ren-ault Airbag reset tool S5.8 - Peu-geot Airbag Reset tool S5.9 - Citr-oen Airbag Reset tool S5.10 - Hon-da Airbag Reset tool S5.11 - Au-di Airbag reset tool by direct connection to EEPROM or MPU S5.14 - Fo-rd Airbag Reset tool by direct connection to EEPROM or MPU S5.16 - Hyu-ndai Airbag Reset tool S5.17 - KIA Airbag Reset tool S5.18 - Le-xus Airbag Reset tool S5.19 - Ro-ver Airbag Reset tool S5.21 - Ma-zda Airbag Reset tool S5.22 - Mit-sub-ishi airbag reset tool S5.23 - Nis-san Airbag reset tool S5.20 - Mer-ce-des Be-nz Airbag Reset tool by direct connection S5.25 - Op-el Airbag reset tool by direct connection S5.27 - Saab Airbag reset tool by direct connection S5.28 - Sub-aru Airbag reset tool by direct connection S5.30 - Toy-ota Airbag reset tool by direct connection S5.31 - Alfa Ro-meo Airbag Reset Tool S5.32 - Fi-at Airbag Reset Tool S5.33 - Po-rsche Airbag Reset Tool S5.34 - Suz-uki Airbag Reset Tool S5.35 - Vo-lvo Airbag Reset Tool S5.36 - Daewoo Airbag Reset Tool 3. CarProg Full Dash:
S7.1 - VAG CAN programmer S7.2 - CarProg Dashboard programming S7.3 - CarProg Dashboard programming package update S7.4 - Me-rce-des Be-nz ASSYST explorer S7.5- VDO dash decrypt tool - Sko-da Roomster, SuperB, VW Polo, A-udi A3, A6, Allroad with 93C86 odometer change and PIN reading S7.6 - Fo-rd odometer change by OBDII (by CAN) S7.7 - VW 2007+ by OBD - Golf, Passat, Eos, Touran, Tiguan, Octavia with Micr-onas by diagnostic S7.8 - VAG VDO dashboards by K-line OBDII diagnostic - VW T5, Passat B5, Sko-da SuperB and others 2J74YA-UDI - Au-di 2J74Y repair software for CarProg 4. CarProg Full Immo:
S4.7 - Kessy tool - A8, Touareg, Phaeton, Cayenne PIN code reader 5. CarProg Full Processor: S2.1 - CARPROG Moto-rola (Freescale) HC05 MPU programmer S2.2 - CARPROG Moto-rola (Freescale) HC11 MPU programmer S2.3 - CARPROG Moto-rola (Freescale) HC08 MPU programmer S2.4 - CARPROG Moto-rola (Freescale) 912 and 9S12 MPU 6. CarProg Full Programmer: ST92 - ST92F120, ST92F150, ST92F250 internal EEPROM programmer 7. CarProg Full Radio Code: S6.1 - CARPROG CC1 S6.2 - CARPROG CC2 S6.3 - CARPROG CCN S6.4 - Ph-ilips Car Radio decoder S6.5 - Ren-ault Car Radio decoder by serial number S6.6 - Au-di/VW/Se-at/Sk-oda car radio decoding software RNS510 - Navigation decoding tool by Navi diagnostic CarProg ADAPTERS: 1: CarProg Main harware interface 2: A1 - OBD2 Adapter Cable (Inside have K-line and CAN bus switches. Use with all cars complained with OBDII standard) 3: D1 - Odometer-airbag Adapter (Dashboard ,Airbag programming adapter ) 4: A3 - Transponder Antenna ( Used with all CARPROG immobiliser software ) 5: A10 - Moto-rola Adapter Cable (Motor-ola MCU programing adapter ) 6: A11 - B-M-W EWS Adapter Cable ( Used with B--M-W Immo software ) 7: A16 - Car radio Cable ( Used for Op-el, Re-nault, Peu-geot, Citr-oen car radio made by Phil-ips decoding) 8: A15 - Cable (Used with D1 adapter ,Universal car dashboard and airbag programming adapter ) 9: A17 - Ho-nda Airbag OBD2 Cable (Adapter for Honda airbag reset by OBDII ) 10: A4 - Eeprom Adapter Cable (Used for eeprom programming) 11: A5 - DIP8 Clip Cable (DIP8 Clip for eeprom programming) 12: A6 - SOIC8 Clip Cable (SOIC8 Clip for eeprom programming) 13: A7 - MB 38-Pin Cable (Used with MB Airbag and dashboard software) 14: A8 - B-M-W 20-Pin Cable (Used with B-M-W airbag and dashboard software ) 15: RNS510 Adapter Cable (RNS510 radio decoding interface cable ) 16: VOL-VO FO-RD CAN 2006+ Cable (Needed for airbag and dashboard programming) 17: FI-AT CAN 2006 Cable (Needed for airbag and dashboard programming) 18: C1 OBD2 Female Cable 19: USB Cable 20: Power cable 21: CD (Software V8.21 + V9.31)
