Perkins EST 2015A v1.0 [01.2015] + Activation
Perkins
Perkins EST 2015A v1.0 [01.2015] + Activation !!!
Perkins EST diagnostic tool Perkins engines.
Region:All regions
Type : diagnostic tool
Brand: Perkins engines.
OS: WinXP. Vista, Windows7
Date of update: 01/2015
EST is comprised of a hardware and software (The Integrated Parts and Service System or( “TIPSS”) interface kit, which a user can use to communicate with Perkins’ 2300/2800 electronic engines (FG Wilson 300 – 750 KVA range) and FG Wilson Powerwizard control panels.
This communication is established via a J1939 data link. All in all, the EST interface kit provides the user with an effective tool in diagnosing engine problems and the ability of configuring system parameters.
EST enables the user to:
Override Powerwizard level three passwords
Configure and/or change system parameters
Display, graph and record logs of parameter status
Display the status of a group of parameters (temperatures, pressures, etc)
View and clear active and logged diagnostic codes
View and clear active and logged event codes
Display, view or change the current Configuration File or Base level Flash File
Upload, download and save configuration files
View a list of irregularities logged by the ECM (engine control module)
Perform diagnostic tests
Perform calibrations
Print reports and diagnostic results.
