Toyota Techstream v16.30.013 [10.2021] + ACTIVATION
Toyota
Versaion:   V16.30.013
Year: 2021
Date of update: 10.2021
TIS techstream is the replacement for the Diagnostic Tester. It combines the functionality of TIS and the scantool into a single portable device. With TIS techstream, technicians can simultaneously view/analyze on-board vehicle data, browse relevant TIS service documents, and reprogram vehicles all from the driver's seat via wireless connection to TIS.
